very small oil leak from Right braided crankcase hose?
Discussion in '6th Generation 2002-2013' started by Skot_2003_VFR800, May 24, 2015.
  1. Skot_2003_VFR800
    Skot_2003_VFR800 New Member
    Charlottesville, VA
    this is the suspect hose. It is located behind the right fairing about the 5 o'clock position in relation to the oil view window. Is there any way to tighten this hose? What is it? The hose itself looks intact to the naked eye. I observed it running and couldn't really see any accumulation of new oil after I cleaned it. I'm wondering if it is just something to tighten down? I'm a little out of my element with it.
  2. Skot_2003_VFR800
    Charlottesville, VA
    This should be it in proper orientation.
  3. Skot_2003_VFR800
    Charlottesville, VA
    it looks like the right oil cooler hose. Can you tighten the braided hose connections?
