VF 500 tapping noise
Discussion in 'Mechanics Garage' started by reg71, Jul 31, 2006.
  1. reg71
    Sikeston, MO
    I have a light tapping in one of the front cyclinders. Gets stronger with higher revs. Oil change didn't really effect it.
    Probable cause? In the manual it says may be piston slap if low speed or during acceleration. It says if knocking or rapping while decelerating may be excessive rod bearing clearance. Suggestions? experiences?
    I talked to my dad and he said, 'You gave $300 for it, just change all the fluids and ride it til it gives out and you came out ahead. Don't tear it apart then you may never get to ride it.' On the one hand, I like the low effort aspect of his solution. On the other hand, I really like this little bike and was hoping to make a daily rider out of it. If I go to the effort of fixing it up, will this ride be dependable enough for my wife and I to take short trips around the state? Most of what I read is good stuff about the VF 500.
  2. elizilla
    elizilla New Member
    Michigan
    Could it be cam chain tensioners?
  3. panamawing
    panamawing New Member
    Nebraska
    I would also suggest checking the valve clearances.
  4. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    It's the lifters. oh wait, V-4's dont have lifters. hmmmmm cam chain tensioners, valve clearance out of spec? Check the simple stuff first before delving into the deep interior of the motor. Is the tapping more like a hollow sound?
  5. reg71
    Sikeston, MO
    Update: ok, I changed the plugs (unrelated, but needed to be done anyway) So afterwards, I ran the bike for maybe 1 minute, I noticed the tapping noise was way less. I could hear it but not like before. I think when I changed the oil I just didnt run it long enough.
    What is the skill level for cam chain tensioners and valve clearances? I may do it tomorrow...
  6. elizilla
    elizilla New Member
    Michigan
    The other thing I thought of, is I had a V4 where one of the valve adjustment nuts backed out and it made an intermittent tapping noise. I didn't get to it quickly enough and that adjustment nut backed all the way off and wrecked things in there. If that's what's going on you'd find it when you check the valves.
    Assuming the 500 has screw type adjusters like the bigger Honda V4s of that vintage, you don't need any parts to do the valve adjustment. All the cost is labor, so doing it yourself is free. If the noise is a cam chain tensioner, it would mean you need to replace it, you'll have to order parts. IIRC Honda updated the cam chain tensioners for all these models. You could order the latest cam chain tensioners from Dodge Racing Products, and in fact you could call Dave Dodge and ask him to listen to the noise and he could tell you if you need cam chain tensioners. (704) 892-7961 Always nice to have the parts already in hand before taking things apart. :) Dave could also tell you what to set the valves to.
    You would get to both valves and tensioners in the same way. I assume you have a basic set of metric mechanic's tools, sockets and allen wrenches and whatnot. Do you also have torque wrenches and a feeler gauge set? Do you have a shop manual?
    The manual says to pull the alternator cover and use a wrench to turn the motor to line up the timing marks. It tells you to get a gasket set for this. You don't have to do that. Instead, you can put the bike in gear and turn the rear wheel to turn the motor, and you can just look at the cams to see where they are.
  7. jchag1718
    jchag1718 New Member
    Louisiana
    It sounds like a valve out of adjustment reg. If you want to adjust them yourself, check "The V-4 Pages". There's a good step by step "How to" and its illustrated. Its done on a Sabre, but it should be the same for the 500.
  8. reg71
    Sikeston, MO
    Ok, I'll take a look there and see if it looks too hard for me to do it. thanks.
  9. reg71
    Sikeston, MO
    Ok. that is good info to know. I will try to get a look at it today. I have to go for a ride first...then a run, then I'll look. I'm glad the little bike is a spare. :) Thanks a lot for your help. I'll keep you posted.
  10. elizilla
    elizilla New Member
    Michigan
    I thought of another thing that may make tapping noises.
    Some of the other V4s have double walled exhaust headers. Dunno if the babyceptor does, I guess that would be something to find out. Anyway, with age and corrosion the inner pipe in one or more of the exhaust headers, can break loose from the outer pipe, and then when you run the bike, the inner pipe rattles in the outer pipe, and it makes an ominous knocking sound that seems to come from the motor. This is a noise that can be safely ignored; it sounds bad but doesn't hurt anything else.
