Vf 750 f engine idle running problem.
Discussion in 'Introductions' started by RajitMattChacko, Nov 12, 2012.
  1. RajitMattChacko
    RajitMattChacko New Member
    Vf 750 f engine idle runing gets off when the engine gets heated up.
  2. TOE CUTTER
    False idle is common on gen 1 and is most likely a vacuum leak, have you checked the boots for cracks or leaks?
  3. squirrelman
    A sign that it may be too rich if it's OK cold but gets worse at temperature. Inspect/clean your air filter. You could try adjusting the idle mixture screws clockwise a bit. You're sure the choke cable is releasing OK ?? A good carb synch might fix it.
  4. TOE CUTTER
    This thread is giving me the feeling of "deja moo".
