VF500 linkage bearings
Discussion in '1st & 2nd Generation 1983-1989' started by jeremyr62, Jul 23, 2011.
  1. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    Does anyone know if these are available? My needle roller bearing in the linkage arm to receive the bottom of the shock is seized solid. All the other bearings seem OK so it's not such a drama but I'd like to fix it as the swingarm is out. The service manual seems to indicate the bearing is replaceable but that might just be the collar.
    EDIT. AT the risk of appearing stupid, I think I might have made a mistake in my assessment of the "bearing". I don't think it is a bearing. Just a flexible coupling. No wonder I couldn't shift it.
  2. creaky
    creaky New Member
  3. jeremyr62
    Ireland
    Limerick, Ireland
    Thanks for that. I'll assume bushing means its just a rubber cylinder bonded to to a steel collar. It's interesting how the bearings in the transfer arm and the dog bones are not replaceable, or at least not listed. I have a Yam FJR1300 and these are a known weakness on that bike. They fail diue to water getting in and then corroding. Maybe the VF is an example of the highly quoted Honda build quaility not being BS.
