Vf500 rebuild
Discussion in '1st & 2nd Generation 1983-1989' started by shortstockevs, Jul 9, 2016.
  1. shortstockevs
    shortstockevs New Member
    Hi all
    Please help
    Just got the bike back together and runs really well.
    However I have a connector that I think is the neutral switch.
    I have touched it to the ground so the bike will start
    But I can find out where it is located.
    Can't believe this is causing me such an issue
    Can anyone help with the location
    Many thanks
    Chris
  2. Allyance
    Allyance Insider
    Germany
    East Bay, California
    On my 83 750 switch is on left side, right above transmission, connector is just past relay and r/r, if that is any help.
  3. shortstockevs
    Thanks don't suppose u got a pic?
  4. squirrelman
    FSM should show the exact location.
  5. Allyance
    Allyance Insider
    Germany
    Here is a couple thousand words, first, the switch
    Then the other end of the wire:
    Should be similar on the 500.
  6. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    Not sure what you mean "I have touched it to the ground so the bike will start"??
    My VF500 doesn't do this. Starter will turn the engine if the engine is in neutral or not.
    There's no switch at the clutch lever like modern stuff has.
  7. shortstockevs
    I can't find anywhere to locate it have a spare wiring loom and there is nothing to connect to?..
    Pic attached hopefully
  8. shortstockevs
    Another pic of where the cable come s from assume this is actually the neutral indicator
  9. shortstockevs
    Come on someone must know just a pic ?
  10. Allyance
    Allyance Insider
    Germany
    Ask "BluemoonerUK", the other 500 thread.
  11. shortstockevs
    Sorry I don't know what you mean
  12. BluemoonerUK
    BluemoonerUK New Member
    Calgary, Alberta, Canada
    Here are a couple of pics of where I think it should go.
  13. Allyance
    Allyance Insider
    Germany
    That looks like it, sorry I mislead you with the 750 info, I guess the 500s are not a scaled down 750!
  14. shortstockevs
    Haha I found it earlier tonight I put masking tape on it when I repainted
    The engine but many thanks for your help
    Cheers
    Chris
  15. Boesjhoar
    Boesjhoar New Member
    Netherlands
    Chris, could you upload a picture? I have the same issue at the moment :D
  16. Mohawk
    Mohawk New Member
    Bristol
    As per the two pics above posted by BluemoonerUK, same on most Honda's I've had the neutral switch is located to the rear of the clutch cover near the swingarm. It is attached to the end of the gearbox.
  17. shortstockevs
    See attached hope this helps
  18. shortstockevs
    Turn it 180 degrees first
  19. Boesjhoar
    Netherlands
    image.jpg this is my missing connector. I don't know where this goes to? FYI I placed a Magna model engine into my Interceptor, because it broke down and I thought that probably it wil fit! :biggrin:
  20. jeremyr62
    Ireland
    Limerick, Ireland
    Where does the other end go to? I have just taken a VF500F engine out of a frame and I don't recall that connector
