VF500 ticking and clacking
Discussion in '1st & 2nd Generation 1983-1989' started by prelude222, Nov 19, 2016.
  1. prelude222
    prelude222 New Member
    Check in search for "VF500 valve problems". How many miles on the little bitch ?
  3. prelude222
    Lol. Little bitch has 30k on her. Always ran fine and quiet. Started up suddenly all at once about 100 miles ago
  4. squirrelman
    Sorry to say, but a sudden noise usually means she's about to blow up like so many other VF500s have over the years, dropping a valve and holing a piston. :sour: :mad: :shame:
    Time to pull the valve covers and measure clearances and inspect things. A chain tensioner problem doesn't just start suddenly.
  5. flattrack
    flattrack New Member
    I would put my money on a failed rocker pad. The flash plating wears through and they get dished real quick. My '85 went from quiet to noisy in about 3 miles. You can find lots of threads on cam/rocker failure. You are looking at replacing rockers and maybe cams. Most people find used parts. Cams can be reground. Hardfacing can be done on both rockers/cams but is pricey. No one wants to shell out that kind of cash for these old bikes.
  6. TOE CUTTER
    I would not start it again. Best to disassemble, locate the problem, and repair before irreparable damage is done.
  7. squirrelman
    Ya know, that makes a lot of good sense! Especially any old rusty dented-tank scratched-up ancient VF (except the 1kR) that needs new tires you just bought for $350 that hadn't run right since Reagan was president and not for the previous 10 years with big expectations like so many before you. :blue:
  8. jrodrims27
    jrodrims27 New Member
    San Diego
    that sounds pretty bad, did anyone pull both valve covers to see if maybe one or more of your valve adjuster screws came off? It happens. Otherwise, I don't think that's a CCT issue. Bent valve or broken valve spring maybe? Have you check for metal dust in the oil for possible rod bearing going maybe? I just had a valve drop on my recently rebuilt 84 which ruined that engine, no warning signs on that one. Do you rev the heck out of it? 30 years+ is really way more than these bikes were designed to live but a few of us love the punishment of trying to keep them breathing with our wallets thinning.
    I did have a similar noise pop up on mine and it was a loose intake boot... probably not the case if you haven't messed with the carbs lately but that or an exhaust leak could possibly sound similar to that and are most definitely worth checking before tearing everything apart or junking the bike.
  9. squirrelman
    Do you remember how many the rpms the engine was turning when the noise started ?
  10. prelude222
    I never bring it above 7-8k rpms
