Vf500 ????
Discussion in '1st & 2nd Generation 1983-1989' started by squirrelman, Oct 7, 2016.
  1. squirrelman
    Need carb info !!
    I' m working on a set of VF500 carbs and need to know whether the larger mainjets go in the front carbs or rear ??
    I can check my SM later, but I'm pretty sure the rear? A little richer for the potentially hotter rear cylinder bank?
  3. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    Depends. It varied from year to year. If they are #92 and #95 mains and 30mm carbs, then the #95 go to the front and the #92 go to the rear.
    If the mains are #102 and #105 and the carbs 32mm, then in this case the larger were fitted to the rear bank. Don't ask me why..
  4. Mohawk
    Mohawk New Member
    Bristol
    Larger main jets go in the rear, the V4s all run richer on the rear bank of cylinders to help with cooling !
  5. squirrelman
    Thanks, gents. This is opposite to the V-2 in the NT650 Hawk, as the bigger jets go in front cylinder. :lemo:
