VF500F motor going bad?
Discussion in '1st & 2nd Generation 1983-1989' started by 243Win, Feb 15, 2009.
  1. 243Win
    243Win New Member
    Just curious here. I've got an 86 miniceptor and the noises from the motor are starting to concern me. The top end sound fine, no noise there. But on the right side down low below the rear cylinders, I'm hearing what sounds like a chain making more noise than I'm comfortable with. Is this normal? Do the rest of you hear the same thing there?
    Just checking before I put this thing up in the air and tear it apart. I'm sort of attached to it as it was the bike I lusted after when I was a broke 21 yr old and I finally got the bike of my "dreams" last March. BTW it has 30k miles on it.
    Thanks,
    Slim
  2. pheonix165
    pheonix165 New Member
    victoria, bc
    my 84 750f does the same thing...my mechanic tells me that while it is not a good sign, it will likely run a few seasons before giving me grief.
    i can only hope the same will be true for you.
  3. Fizz
    Fizz New Member
    San Diego, CA
    Get the valves adjusted.
  4. gunnarf06
    gunnarf06 New Member
    Hafnarfjordur
    One idea here
    Hey guys
    I have 700 ´84 model and I don´t want to spoke you.But I heard a noise like you have dropped a penny down in the basement.Little after that 3-4 months later one of my main bearings breaks up but my tensionor and chain were also in bad shape.And now when I tried to use the same chain my camshaft were off by half tooth so that means also that my bike had to be running on wrong time.I would check the time on the camshaft and the tensionor.But so you know you don´t have to tear the whole engine apart to change the chain.Just see my forum "Need help setting time on my 700F".
    Best regards
    Gunnar
  5. 243Win
    243Win New Member
    Doesn't have a valve like sound, it's not a tapping/clattering sound. But, once I have it up in the air on my hoist, those will obviously get checked.
    The sound is a whirring, chain-like rattle, not valve clatter or rod-knock.
    So, other than this sound, how does one determine if a timing chain is bad or a tensioner has gone slack?
  6. gunnarf06
    Hafnarfjordur
    Hope this help
    Hey guys
    You can set the time and see if the camshaft are right set.With the tensioner you can hear,see or feel.If they are gone bad your chain gives a noice like you discribed,feel the slack and you can also see it is discribed on the forum "Need help setting time on my 700F".Mine is driven 26 miles and had bad chains and tensioner.But I think that was the others owners that didn´t take care of the bike.
    Best regards.
    Gunnar
  7. mello dude
    I had a VF700 Sabre that esentially did the same thing as all the above. Eventually there was crack metalic sound and it ran no more. Sold the thing for a give away price.
    MD
  8. gunnarf06
    Hafnarfjordur
    Hey
    And there went your one of your rod bearing or main.
    Best regards
    Gunnar
  9. TOE CUTTER
    stop
    I would not start it again until you figured out what it is. When these bikes let go the damage is usually quite wide spread . You may save yourself a lot of time and money if you figure it out before failure. Good luck.
  10. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    the plastic on the chain tensionor could be worn that is not a hard fix veirfy the problem first, becouse this thread looks like its going to send you on a wild goose chase!!!! :thumbsup:
  11. 243Win
    243Win New Member
    Ah, a goose chase just makes it all the more fun. I've got three other bikes to ride while I baby this one. I'm a fair mechanic and I've got two miracle mechanics in the neighborhood just dying to figure it out. It will work out.
    While it is apart, I can get the rear shock done and do the conversion to 17 inch rims as well.
    It's all good. :thumbsup:
  12. Pcohen
    Pcohen New Member
    jonesboro, arkansas
    If your interested I have 2 almost brand new chain tensioners i can sell you. They have about 1500 miles on them and i bought them new from the local Honda shop.
  13. 243Win
    243Win New Member
    PM Sent
    10 characters,...
  14. matt1986vf500f
    thats what im doing to mine, good luck, go check out my thread.
  15. 243Win
    243Win New Member
    Yip, I've been following that thread. Good tip there on the rotors. A cat sprayed mine and I didn't notice it until too late. Etched them somewhat so I was looking for replacements. The rotors in your thread look the same as the ones I put on my GSF400 Bandit. Cost the same too,... Ouch.
  16. matt1986vf500f
    ebc sells rotors for the vf500s but very very expensive
  17. 243Win
    243Win New Member
    Yeah, those were the ones I put on my bandit and yeah, they were expensive and that was for only two of them, not three!
    Anyhow, back to the motor. Is it going to require pulling the motor from the frame to replace the tensioners if that is what I find is bad?
  18. matt1986vf500f
    i would say so, the man you really need to talk to is jamie on the internals of the vf motors, he can walk you though the steps, but if that is the problem then yes the motors has to come out.
  19. 243Win
    243Win New Member
    Clymer manual keeps re-iterating if you have to pull the cams, pull the motor so I guess that will be the plan. I have the factory manual too.
    Better clear off more bench space,...
  20. matt1986vf500f
    get ready its going to be a bitch!!! :chairshot:
