Wanted VF500F tank mount rubber 17611-KE7-000
Discussion in 'Classifieds' started by Jim McCulloch, Jun 1, 2020.
  1. Jim McCulloch
    Jim McCulloch New Member
    Does anyone have one they want to part with?
    It goes here on a VF500F...front of the frame under the fuel tank.
    Is it something you could cut yourself? If so, you can source quality sheets of rubber off Amazon for a couple bucks.
  3. raYzerman
    raYzerman Member
    Millgrove, ON
    Try a fuel tank bumper from a Gen5?? I'll post a pic later and see if you can adapt.
    I might have one I'll part with. I need to assess my inventory. Luckily these don't get lost as easy as the 86 VFR style.
  5. Jim McCulloch
    No rush on that! I appreciate the effort. I have a lot of jobs to do before I need to mount the fuel tnk again.
  6. Jim McCulloch
    I have tons of automotive bumpers and looked into modifying but this one has a molded curve in it that makes it tough. I have some old GSX650F rubber that was so close but no cigar.
  7. Jim McCulloch
    Yeah, I used to have a VFR800FI and they do look similar if memory serves. Been a while though.
  8. raYzerman
    raYzerman Member
    Millgrove, ON
    Gen5 VFR tank rubber for reference, if you look at the thin side, it clips over the edge of the tank and remains exposed. The thick part is under the tank and there's another curved piece glued to the tank, which is glued to the ribbed edge of the rubber (see residue on radius).. see part diagram....
  9. Jim McCulloch
    Thanks for taking those pictures. Not sure that is going to work out of the box. The VF500 part is a right angle with close to the same thickness overall.
