Vf500f2f 1986 chain
Discussion in '1st & 2nd Generation 1983-1989' started by shortstockevs, Aug 21, 2016.
  1. shortstockevs
    shortstockevs New Member
    Hi gents
    Just putting on new chain 530 130 link chain
    However under adjustment the wheel adjustment is almost all the way back.
    Surely this can be right?
    I could actually cut a link out and have the wheel at the very front of the adjustment?
    Seems a bit daft any opinions
    Chris
  2. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    130 links? Standard is 108. Stock gearing?
  3. shortstockevs
    Oops apologies
    108 links
    Front Sprocket Teeth: 15 | Rear Sprocket Teeth: 43 | Chain: 530VX GB x 108
  4. jeremyr62
    Ireland
    Limerick, Ireland
    If you have no adjustment left to take out the slack when the chain wears, then yes, something is very odd. If the wheel is back as far as it will go then this will be the case. I can't think what it might be, other than you actually have an extra link or the sprocket pitch is machined incorrectly. 108 including the split link?
  5. shortstockevs
    Yep 108 strange did web site refers to 1986 with 106 links unless the f refers to a French model??
  6. jeremyr62
    Ireland
    Limerick, Ireland
    When I did a 17 inch conversion on my 86 I changed the gearing from stock to 15/41. This meant the wheel was too far back so I had to take a link out. I do remember counting the links and 108 is right, not 106. I reckon that's a typo in the DID chart.
