vf700f front end swap #2
Discussion in '1st & 2nd Generation 1983-1989' started by axle54, Jul 20, 2010.
  1. axle54
    axle54 New Member
    lomita, ca
    so the bikes a front end off a yamaha yzf on it for a while, but i finally needed it back for the yam, so looking around ebay i found this complete front end for about 100 bux off a 1990 vfr750. much easier swap than the yzf front end cause i can switch back to the original tripples. only bummer is i loose the speedo cable, but i can just use a digital one. still gotta mount up the front fairing and paint everything but its coming along. anyone know if the vf1000 rear wheel will swap out or is the swingarm and everything different sizes?
  2. TOE CUTTER
    Nice upgrade but what of the back wheel?
  3. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    The VF1000F wheel will fit without modifications. Just make sure to use the 1000's caliper bracket as it's rotor is not the same size.
  4. MPM
    MPM New Member
    Rhode Island
    Any details on the front end swap or is it pretty much a direct fit? Are there any clearance issues?
