VFR 700 ignition switch replacement
Discussion in '1st & 2nd Generation 1983-1989' started by carbon, Sep 8, 2008.
Tags:
  1. carbon
    carbon New Member
    So I recently acquired a 1986 VFR700 in 3 boxes of parts. After spending a weekend with it, I have it mostly together, however I am missing a few key parts.
    First is numerous nuts and bolts. Is there a stainless bolt kit available?
    Second is my ignition switch and tank cap are missing. Where can I get replacements? Ebay does not seem to have anything...Unless I can use the switch and tank cap from a different year/model of bike. Does anyone know if a cbr or later vfr switch/tank cap will fit an 86?
  2. digdoug2
    digdoug2 New Member
    Elkton Maryland
    For my 87, there were numerous years of many different bikes that would fit. The main thing is how many wires does your plug require? I would say 6 if it is the same as mine, which I think it is. Mine actually was for a CBR1000. Do you have any parts of the existing ignition? If not, I can show you what it should look like. I'll look on ebay and see if I can find one that should fit.
  3. squirrelman
    lotsa yen for the Honda part, but the Dennis Kirk catalog has one that will work cheaper.
    or junk yards cuz lotsa other Honda switches work too.
  4. digdoug2
    digdoug2 New Member
    Elkton Maryland
  5. carbon
    carbon New Member
    Hey thanks for the responses. I have most of the ignition. The coils and wires appear to be intact, but I probably won't know until I start plugging things in. So, other year tank caps may work? Looks like I *just* missed that cap and switch auction.
  6. Rayman
    Rayman New Member
    I just purchased Same bike and am now in need of same ignition switch. also need a Rear cowl or panel part above tail-light.
