VFR 700 will not rev past 3500
Discussion in '1st & 2nd Generation 1983-1989' started by artee, Feb 24, 2011.
  1. artee
    artee New Member
    Rochdale,
    Hi all
    My vfr 700 F2 California will not rev past 3500, when the throttle is opened the bike wants to stall.The bike idles fine
    I probably know the carbs will need a good cleaning, but is there something so simple that I could have overlooked.
    Bike is in a state of semi restoration, and has been stood without any fuel in the carbs for a couple of months. I havejust refitted the fuel system (new lines and filter) after the respray, started the engine, warmed it up and it will not rev.
    HELP please.
    Roger
  2. crustyrider
    crustyrider New Member
    North Country, New York
    make sure you have no vacume leaks...... check your voltage to the little black boxes (under the seat) but clean the carbs first eliminate that...your carb boots are probably rock hard and in need of replacement.... and if you have all the california goodies still attached , make sure the vaccume lines are al connected and have no leaks...
    Good luck
  3. artee
    artee New Member
    Rochdale,
    What voltages under the seat? can you tell me more please.
    bike ran ok before lay up, will check all pipes etc..
  4. crustyrider
    its the little black box under the seat ..this operates your pulse generators check electrical connections first, unplug them inspect clean if nessassary apply some dielecrtic grease... plug back in... the problem is "simple" you just have to eliminate all the possibilities...
  5. squirrelman
    Check that all 4 cylinders are firing by lightly touch each header pipe; if you can isolate the problem to one cylinder, begin troubleshooting there.
    Check that the carb vaccum slides are working and not stuck.
    If the bike sat for a long time you may need FRESH fuel.
  6. artee
    artee New Member
    Rochdale,
    Problem solved I think.
    When I first got the bike I noticed a pipe from one of the Cali emmision valves seemed to be not connected to the carb, so I connected it.
    Today I removed the pipe and the bike now revs.
    Now to sort out the wiring from the alternator.
    Some dozy prat as cut off the socket that plugs in to the regulator and used spade connectors to attatch them to the regulator plug, the problem is I have noticed the wires get so hot that the insulation has burnt away.
    Thanks to all those that replied
    Roger
  7. crustyrider
    Prat....I love that word.....Prat Prat Prat Prat Prat Prat Prat Prat.
    congrats hopefully you found the rpoblem
  8. artee
    artee New Member
    Rochdale,
    Do you not use the term "prat" on your side of the pond then?
    It's a little more polite than calling someone a complete douche, I suppose
  9. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    I haven't heard prat. I have heard knobbie, though.
  10. TOE CUTTER
    I am gonna stick with complete douche bag myself.
  11. rpierce
    rpierce New Member
    Dayton, Ohio
    Personally I think twat is better than all of the above
