Hi all - I'm trying to install a ST2 Strober (pulser) to my Brake Lights. Can anyone tell me which wire is the Ground Wire and which is the Signal Wire? I have 3 wires going int to the taillight - stoplight: Green Green w yellow stripe Brown The people at ST2 didn't know and suggested: "You can test the wires with a multimeter. On the multimeter, you’ll need to find: Power wire = 12V with ignition switched on Signal wire = 12V when brake lever is pressed" Since I'm not experienced with a Multimeter, I thought I would ask here. Cheers – Jeff 1994 VFR750F
