VFR 750 RC24-I front forks rebuilding
Discussion in '1st & 2nd Generation 1983-1989' started by Elia Crocetta, Sep 5, 2024.
  1. Elia Crocetta
    Elia Crocetta New Member
    Italy
    IMG_8750.jpeg Hi everybody, I’m doing a rebuild of the front forks, but I’m not sure about the order of the spacer seats. In the picture attached, which one should be on bottom of the spacer and which should be on top? Is it ok as shown (blue on the bottom, yellow on top)?
    For reference:
    blue sits on top of the spring, other one top of spacer. check the manual to b sure.
  3. Elia Crocetta
    Italy
    The manual is not that clear, it calls both “seat spacer” and in the drawings they have no differences.
    anyway it makes sense the way you said it, thanks
  4. Elia Crocetta
    Italy
    I’ve got another question.
    IMG_8757.jpeg The bolt on the right is the original one, which was stuck and I had to broke the hexagonal inner shape.
    The bolt on the left is something I bought in a hardware shop.
    Do you think could be good for the purpose, or should I buy the original one?
    For context, we are talking about the number 45 in the scheme.
    That's probably just fine. The only thing I would consider is the depth of the allen hole. If it is less than the original, there's even a bigger chance the next removal will also round out.
    And it really makes no difference on the fork spacer washers. I think I usually find the dished one in the cap. You could use just all flat washers too. My OCD would compel me to be consistent tho.
  6. RogueRC24
    On the screw, I think you could use a standard Socket Head Cap Screw. I am still unsure as to why the fork end bolt heads are so short. So far I have not seen a axle that was "that close" to the head to matter. But I have been wrong many times before. lol
    Pretty sure I have used normal cap bolts with no issues. A Torx head would be pretty nice too
  8. mello dude
    Romania
    I would be more conserned what grade the bolt is...
    Grade 8, 10 or 12 ... in reference to metric bolts. I would go at a Grade 10...
    There is a difference in Grades of standard vs metric...
    Are there markings on the OEM bolt?
