VFR 800 07 Gearbox
Discussion in '6th Generation 2002-2013' started by Mike-r, Oct 10, 2016.
  1. Mike-r
    Mike-r New Member
    So as some of you know I picked up a clean not so much used VFR.
    Just a question though. The gearbox? Does it feel like there is a slack in gear changes? Hard to describe. Like when you are in 1st gear and release the clutch slightly as if you are about to pull off there is a clunk. Like it didnt engage fully and needs that extra click in the gearbox to touch the gears. this normal or must I get it checked out?
    Sent from my SM-N910F using Tapatalk
  2. Terry Smith
    This will depend on what you are used to. My 5th gen gearbox felt pretty slack and clunky as well, as I came off a Suzuki. I found installing the FactoryPro shift kit (which replaces the shift star and detente wheel in the selector mechanism) made a noticeable improvement, and my VFR now shifts really well.
