Vfr 800 Fi Interceptor Wont Start
Discussion in '5th Generation 1998-2001' started by george.a.hill1, Jan 13, 2015.
  1. george.a.hill1
    george.a.hill1 New Member
    Málaga, Spain, Spain
    hello i have just completed a top end rebuild on my vfr 800 fi 1998 and it is not starting it lets out flames from cylinder 2 and 4 and will start but no0t stay running unless running using easy start have to keep spraying it in
  2. skimad4x4
    France
    French Alps & London
    Hi George
    Welcome to the MadHouse:welcome:
    It sounds like you are already having fun with your VFR!
    It might help us understand what might be wrong if you can supply a bit more information. Why exactly did you end up rebuilding the top end of the bike? You know this stuff but we don't - so don't worry about keeping this sort of post short - before people can offer any practical input we really need a better understanding of the bikes recent history. How many miles? when last serviced? Are there (were there) any MIL codes? Has the bike had any electrical issues? Has the bike had any aftermarket mods applied .. power commander?
    I am guessing from the work done it suffered some serious mechanical failure in the top end, but do you know if the bike was running OK before that? Or are you engaged in a Lazarus mission trying to fix a defective bike which has been abandoned by its previous owner?
    As for the bike being unwilling to idle, the ECU and a heap of sensor inputs controls pretty much everything on these FI bikes, so you need to ensure all the sensor inputs are connected, likewise hoses for things like the crankcase ventilation on the airbox.
    If the problem is associated with only one bank of cylinders then perhaps start by checking things like leads and coil packs for those cylinders are correctly connected up. If they all look OK. then maybe swap components like coil packs plugs etc. over to see if the defect relocates to other cylinders.
    Good luck
    SkiMad
  3. george.a.hill1
    hello yeah well i got the bike with a water leak going into oil but it run and rode perfect.
    i set up taking top end apart and found out it was the head gaskets so i replaced them and put the bike back together following step by step manuel and videos on youtube i triple checked the timing and even got a friend around to check it was all perfect and spot on.
    i set about putting engine back in the bike done that but before i put the panels and everything back on because i thought i would getthem sprayed whilst i was working on the bike. so before i out them back on twhilst the bike is bare just tank and clocks i tryed starting it up used a bit of easy start nothing but if i constanlt spray easy start in there it will fire up or sometimes even through flames out the injectors back towards me through the airbox hence the reason me posting on this forum now as i really need help im just totally lost with what to do now hope thats enough info if need anymore just message me
  4. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    Are you sure you didn't get the exhaust and intake cams or timings mixed up? Seems like its trying to exhaust out of the intake. I would bet the timing is way off somewhere since it seems the your intake valves are open during combustion.
  5. squirrelman
    Me too^^ You most likely have mistimed cams.
  6. george.a.hill1
    i will check but i cant see myself doing that and i know the timing of the engine is spot on i have checked that atleast 3 or 4 times now but the cams sound like a good place to look thanks
  7. george.a.hill1
    all sorted now it was a matter of turning the engine over 189degress before doing the 4t timing the manuel didnt add that in i got advice of another mechanic friend thank you for your help people i really appreciated it
  8. BWeiss
    Rancho Cordova, Ca
    That's what this place is all about. Glad to hear you got her going!
  9. squirrelman
    Yer lucky ya didn bend some valves,and turn the bike to basura Bunky !!!
    :shame: :drunk:
  10. BWeiss
    Rancho Cordova, Ca
    I'm sure this has been covered somewhere, but is the 800 an interference motor?
