vfr 800f1 no power
Discussion in 'Introductions' started by garry thompson, Sep 22, 2013.
  1. garry thompson
    garry thompson New Member
    hi i have a 2001 vfr800f1 when i turn the key on the immobiliser lighy flashes and theres a clicking noise but the whole of the bike is dead check battery and all of the fuses all ok any ideas welome please
  2. skimad4x4
    France
    French Alps & London
    Hi Garry
    I should of course start by extending a formal welcome to the MadHouse:welcome:
    Assuming we can discount the usual - knocked the engine run cut-off switch and such like - it would help us, if you can provide a bit more information - chances are you are seeing/hearing stuff which might help diagnose what is going on. Is there any chance you can post up a video showing what is (not) happening when you try to start the bike. The easiest solution would be to upload a video to YouTube.
    You don't say how long you have had the bike or whether this is a sudden/new problem or the bike has been left for years and you are now trying to get her back to life. The more information you can provide the better chance we will have of being able to point towards possible causes/or likely solutions.
    I assume you know that normally the FI light should light up as part of the start up process but then go out. If it flashes then it probably means the PGMFI system has a stored fault code which may be the key to whatever is wrong. Have a look at this video - Reading Fuel Injection Error codes on a VFR800 - YouTube
    and see if that sheds some light on things.
    Let us know how you get on.
    SkiMad
    PS When you get a chance mosey on over to the introductions thread and post up a bit about you and some pictures of your VFR.
  3. garry thompson
    Hi sorry I've had the bike for a month it's been fine until two days ago had it running turned it of five later wouldn't start turned the key the green immobiizer light flashes and the three lights on the dash take time to fully illuminate if I press anything lights.horn starter lights on the dash dim but nothing happens
  4. skimad4x4
    France
    Right, so my first thoughts were completely wrong... Which points towards either the charging system and well documented RR/stator/flat battery issues ( search for posts by Rubo) - or more likely a fault with the alarm/immobiliser system - which, give it its due, is indeed leaving the bike immobilised!
    The bike is too early for the full Honda HISS system so I assume the bike is fitted with some sort of add on unit like a datatool immobiliser. (All such systems are pretty much spawn of the devil and can cause endless grief to owners, but won't stop a determined thief.)
    Anyway you need to dig out the paperwork which came with the bike and read through until you find the fault finding guide for the alarm system. Hopefully that will allow you to sort out what is wrong - it could be as simple as the battery on the bike, or inside the alarm or key Fob has drained and needs replacement.
    If you can't locate the paperwork then try the web/call the manufacturer. However most firms will only supply information to a person who is the officially recorded owner/keeper - so you may have a bit of an issue until DVLA turns up with paperwork to show you as the new owner.
    Sadly most modern systems do not have a manual(key) override allowing you to turn the damn thing off if it starts misbehaving, but its worth locating the unit and seeing if there is any sign of a key slot which will at least allow you to get the bike working whilst you figure out what is wrong with the alarm.
    If all that fails - then the only solution will be to call in an installer who knows that make/model of alarm. Sadly these things tend to be all computer chips with nothing to fix so you may find the cheapest fix is to get the alarm specialist to completely replace the old unit. On the face of it, if the battery is in good health then its probably not the bike which is causing the problem - just the aftermarket alarm.
    Sorry I can't be more helpful. Let us know how you get on.
    SkiMad
  5. garry thompson
    Hi the bike was one of the very last f1 it is fitted with the hiss system bye the way thanks for your help
  6. Scubalong
    Sound like your battery is shot
    :welcome: to our little world mate, have all the recall have been done? Let check the battery and all the connectors first.
  7. YAUGURU
    YAUGURU New Member
    Lynchburg, VA
    BATTERY, check the RR ..
  8. garry thompson
    Looks like the battery jumped it off this morning started first time thanks for the help
  9. Scubalong
    You are welcome, best just get another battery before she leave you stranded.
