VFR and CBR compatibilities
Discussion in '6th Generation 2002-2013' started by Guj, Jan 30, 2012.
  1. Guj
    Guj New Member
    Central Minnesota
    I was wondering if there are any compatible parts between the 2003+ models. (6h gen VFR and 600RR or 1000RR's
    I specifically was thinking about the suspension (shocks front and rear) and bakes (rotors, pads, and calipers).
    It’s not that I am unsatisfied with either, but if I could find a cheap swap I would be interested in doing it for a ‘just cause’ type scenario.
  2. reg71
    Sikeston, MO
    I know that the rear shock from a 929 has been swapped to both a 4g and 5th gen VFR before, but I do not know specific years, and I am not sure if I know anyone who has used a rear shock from the cbr1000 on a VFR at all... Did you try a search for the specific parts you want to check like: "rear shock swap" or something like that? You may be able to find some helpful info but it might take some digging.
  3. Metallican525
    Metallican525 New Member
    Rockville, Maryland
  4. Guj
    Guj New Member
    Central Minnesota
    Thanks for pointing me in the right direction!
    Some food for thought while I tackle the VTR fan swap.
