Vfr front end swap
Discussion in 'General VFR Discussions' started by Youngbuilder, Jun 27, 2015.
  1. Youngbuilder
    Youngbuilder New Member
    So let me begin by saying hello to you all. So I guess my first post will be a question I don't have a vfr yet, but hope to get one someday. I've read it's an awesome motorcycle.
    What I do have is a 1974 cb750. I picked up a 94 - 97 vfr front end for cheap. Problem is It didn't come with the wheel or brake disk, not a problem. I will using the cb750 hub on it.
    So my question is can some give me the measurement of distance between the outer surfaces of the brake disk ? With this measurement I can figure out how much offset I need on the disk I will be using.
    Also the measurement of the hub surface where the disk sit may help
    The hub measure may be tricky unless some one has a bare wheel sitting around.
    Thank you guys for looking and hopefully answering
    Welcome !! :welcome:
    That project seems pretty much nonsense ! :crazy:
    I had an old '73 CB750 on the road for a couple years, and imo, it's nowhere near as safe to ride as newer bikes with improved wheels, tires, brakes, suspension and a whole lot lighter. Grafting some cool VFR bits onto the CB's creaky crawly chassis won't make it any safer and will make it less valuable as a relic. :shame:
    Measurement of the different fork lengths, etc. and getting good numbers within a workable range is job #1 or the fancied-up old slapper may be too hard to handle.
    A decent old, tired CB750 usually sells for about $1000, so sell yours, save up an additional $1000 and step up to a VFR750 from CL or ebay. Makes more sense technically and financially imo.
  3. Youngbuilder
    Well I knew someone would say something like that. There's always someone
    It's not a stock chassis and no disrespect man but you probably never got to know the bike long enough. It's not the chassis that was a weak link but chassis components. That being said I like old bikes. I got the frond cheap and I know with a little more money and time it'll work.
    Ps. Don't be so negative man I asked for a little help not someone to bring down my project
  4. Youngbuilder
    Can someone pease help me out just need the distance from outside to outside of rotor surfaces
