VFR nutral light
Discussion in 'Introductions' started by hawkeye, Sep 26, 2006.
  1. hawkeye
    hawkeye New Member
    Perth Western Australia
    Having a problem with nutral sensor failure .Can not start without engaging the clutch and cant put side stand down without engine cuting out ,nutural light dosent work wen in nutural.Problem was intermittant but now seems permanant.Its not a magor problem just frustrating
  2. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    It could be a bad sidestand switch. When you put the sidestand down and the engine stops, is the bike in or out of gear? I have a problem with my sidestand light staying, but it is exhibiting no harmful side affects otherwise.
  3. squirrelman
    check it out!!
    quite possibly a failure of the starter system DIODE.
    not sure where it's located on your bike.....read shop manual!
    "always preserve nature"
    or try turning your bike upsidedown, so it works like our bikes here do................
  4. Davidvfr
    Davidvfr New Member
    Concord West, NSW Australia
    I had a similar problem with my '00 model a while back.
    A worn switch was found to be the culprit. I'll have a look to see if I can find the service docket.
  5. RVFR
    Hmmm double check that side stand switch thou the neutral locate switch that lights the light. may be an indecation yhat there's more to this, good luck keep us inforem how it goes
    All in know is if I put it in gear and try to go with the side stand down she dies. lol telling me that I tarded out again. luckly that doesn't happen very much
  6. Davidvfr
    Davidvfr New Member
    Found the receipt.
    :smile:
    My bike occasionally wouldn't light the neutral light when it was in neutral. Never happened when the engine was cold, only once it had been running for a while.
    The dealer found a switch was worn, it looked a bit like the top of a pen where you push down so that the business end comes out of the other end of the pen. (If that makes any sense.)
    My receipt says that the part that needed to be replaced on my bike was a SW.ASSY.,NEUTRA! Part # 35600-KE8-003 Cost me AUD$19.90 for the part. My dealer gives me 10% off on parts, so it may be a bit dearer for you. And my bike is a 2000 model as well.
