VFR12 Engine Oil
Discussion in '7th Generation 2010-Present' started by rhodesda, Dec 3, 2014.
  1. rhodesda
    rhodesda New Member
    Hamilton, New Zealand
    Hi Everyone :smile-new: I've just brought a new VFR12 and was wondering what oil you run in your engines, Full Syn or Semi Syn ? and what brand ? I own a Blackbird which I run Semi Syn oil (Castrol)and in my VFR800 I run Full Syn (Castrol)
  2. mcenthusiast
    mcenthusiast New Member
    Auburn, CA
    Hi Rhodesda! I purchased my VFR1200F in late November, 2013. I changed the engine oil and filter at 100 miles and again at 600 miles. I did these frequent oil changes as part of the engine run-in protocol that I follow. At these initial two oil/filter changes, I used Honda GN4 10w-30, a petroleum based oil. When I changed the oil/filter next at 2,000 miles, I changed to Honda GN4 10w-40, still a petroleum based oil. It was nearing summer and I knew the temperatures would be much warmer; therefore, the change from 10w-30 to 10w-40. The next change was at 4,000 miles. For this change, I switched to the Honda HP4 10w-40, which is a synthetic petroleum blend. From this point on, I will change the oil/filter at 3,000 mile intervals and will continue to use the Honda HP4 10w-40 synthetic petroleum blend. Hope this info is useful for you.
  3. cornerexit
    cornerexit New Member
    Full synth. Rotella or Amsoil.
  4. rhodesda
    rhodesda New Member
    Awesome :smile-new: Thanks for the feedback, I think I will be using the same service intervals also :thumb:
  5. cornerexit
    Have it lab tested so you know exactly when to change it.
