VFR400r (NC24) - Rothmans Build.
Discussion in '1st & 2nd Generation 1983-1989' started by Diving Pete, Apr 12, 2019.
  1. Diving Pete
    So this will be a little like my last thread (just QUICKER) but will end up with a Rothmans Version. Now personally I think this was the best colour scheme Honda ever made with the RC30 scheme a very close 2nd.
    Overall the bike is in pretty good condition but has been stored ineptly. The bike visually needs a fair amount of love, has low miles & is a good candidate for bringing back to life. I have not yet run it ! I will be getting the bike running, replacing a few parts, repairing what I can't replace - I do have a few spares - lol, & then painting the fairings & tank..
    So today I'm taking a close look at the tank. The tank has minor bubbles in the paint (BUT IS DENT FREE !!!!) - so I'm guessing rust from inside. A quick look inside the tank shows signs of bad storage & signs of rust.
    [​IMG]P1080182 by Pete Smith, on Flickr
    Damm - It's not looking to be a good start.
    [​IMG]P1080191 by Pete Smith, on Flickr
    So the plan is to put Hydrocloric acid (also called Muratic) in to get rid of it.
    Started on the VFR tank, started to empty it, had about a gallon of fuel in it & it wasn't new fuel - bike was last ran in 2015!!!
    Drained most of the fuel out of the tap, then removed it & the cap.
    Then shook the tank..
    It made a LOT of noise....WTF ! I just drained the fuel..?
    Took a CLOSER LOOK inside . hmmm
    What is this.. - Bits of plastic... epoxy !
    [​IMG]P1080194 by Pete Smith, on Flickr
    This pile took 2hrs to remove..
    Holy Baloney!!
    It looks as if at some point someone has sealed the tank (BADLY) to the point it has now FAILED & bits are floating around inside the tank... ARGHH.. Need to remove this crap before I put the acid in so that's this mornings job.
    kept pulling more out.
    [​IMG]P1080206 by Pete Smith, on Flickr
    In total 4 hours it took me to even get the tank ready to put the acid in !
    its not that good a start.. lol
    Gonna be following along, Mr. Pete.
    The darkest hour is always when you take out that first bolt and you think to yourself, "Self, it can only get better from here".
    Just a little encouragement.....
  3. reg71
    cool. this should be fun to watch. not so much to do, but to watch, yes.
  4. Diving Pete
    Yep - the aim is finish it by September.
    The carbs I took off & amazingly were actually almost clean so now off the bike & just waiting on a rebuild kit. P1080442.JPG
    However, it was not exactly loved - lol
    I have thrown on my spare set of carbs to just check it works fine & then I'll rebuild the original set, clean up the V, paint the engine & Valve covers & check the valve clearances. Then I can pull the subframe, refresh that but hopefully I'll start it this weekend...
  5. NorcalBoy
    Good on ya for bringing another one back, Mr. Pete. That thing is lucky it was adopted by you, that's all I gotta say.
    I like looking at the subtle differences between the 30 and the 35. They really aren't that similar in a lot of respects. You can get a little bit of an idea from the FSM for the 30, but it really becomes apparent through your detailed photos.
  6. Diving Pete
    its a 24 - the earlier version. I think they are even rarer than the 30 or 35 in the US... lol
  7. NorcalBoy
    I could tell from the title of the thread and also from the external oil line in the V photo, prolly should have been a little more clear, what I was meaning to convey was that your detailed photos from all of your work is great to compare all the different model layouts. Basically, you take great pics and I like the detail in them.
    Diving Pete likes this.
  8. Diving Pete
    LOL - thanks for the compliment...
    I really enjoy getting these bikes alive - they are everything that I hate in the newest modern generation of vehicles - traction control, ABS, anti-launch, blah, blah, blah, basically electronic controls...
    Bikes are to give me the control, freedom, & choice to screw it up - Its up to me to avoid that by raising my game. There will be times when I get it wrong - I take responsibility for my own actions.
    These bikes allow me those freedoms - it also helps they are Honda V4's & excellently made...
  9. NorcalBoy
    Light weight, amazing lines, excellent chassis, no nanny aids, decent power, legendary engine config, great bloodline....what's not to like :Noidea:
  10. Diving Pete
    I'm very conscious that it doesn't look like I've done much with this - BUT I have lol..
    So I eventually got the thing running in June - it had been sat since 2015 & not stored correctly... During the run I discovered that the exhaust collector was rotten. This then led to the following outcome - which is the most I've ever done on a single bike.
    We all love pics so here you go:
    Starting to strip it down..
    [​IMG]IMG_1862 by Pete Smith, on Flickr
    Back is slightly dirty...
    [​IMG]IMG_1869 by Pete Smith, on Flickr
    At least the Oil rad is in a reasonable condition.
    [​IMG]IMG_1870 by Pete Smith, on Flickr
    Don't think they cleaned in this area either...
    [​IMG]IMG_1872 by Pete Smith, on Flickr
    I'm sensing that its not been cleaned or polished for a while..
    [​IMG]IMG_1879 by Pete Smith, on Flickr
    Well its out..
    [​IMG]IMG_1889 by Pete Smith, on Flickr
    Just as uncared for as the rest..
    [​IMG]IMG_1891 by Pete Smith, on Flickr
    NorcalBoy likes this.
  11. NorcalBoy
    Back at it, I see. Looks like another child abuse victim...seen one of those somewhere else before....:Whistle:Can't wait to see what ya do with it as the project progresses.
  12. Diving Pete
  13. Diving Pete
    I'd actually forgot - I lost the use of the garage for 4 months as we had really strong winds that ripped the roof off it & it took a while to get fixed - along with some subtle upgrades (Skimad4x4 also helped).. This did slow the project a little - lol
  14. Diving Pete
    This engine took MANY HOURS to get clean & I'm 80% happy with it.
    [​IMG]IMG_2031 by Pete Smith, on Flickr
    getting good at masking up..
    [​IMG]IMG_2035 by Pete Smith, on Flickr
    [​IMG]IMG_2036 by Pete Smith, on Flickr
    A couple of weeks ago it was put back in..
    [​IMG]IMG_2041 by Pete Smith, on Flickr
    You can just see the rear stainless pipes.. - The new system is beautiful.. From Predator Motorsports - took over 3 months to get.. - He did warn me about this as he moved site 2 days after I ordered it !!
    Painting bits...
    [​IMG]IMG_2044 by Pete Smith, on Flickr
    More bits painted - along with the frame (before the engine went back in LOL)..
    [​IMG]IMG_2045 by Pete Smith, on Flickr
  15. Diving Pete
  16. Diving Pete
    Valve clearances all checked & adjusted to correct - a couple were touch tight but nothing major. I'm happy that it will run fine once the electrics are plugged back in although I still need to check the stator - the connector looks to be non standard.
    The rear brake bar - yep equally unloved..
    [​IMG]IMG_2110 by Pete Smith, on Flickr
    time to do some work on the back..
    [​IMG]IMG_2111 by Pete Smith, on Flickr
    [​IMG]IMG_2112 by Pete Smith, on Flickr
    So this is where we are now..
    Rads on, Oil back in, just starting to button it up a little..
    [​IMG]IMG_2114 by Pete Smith, on Flickr
    Colddevil likes this.
  17. Diving Pete
    The entire front end will be removed - Have a set of powder coated triples & wheels to go on, the brake lines will be stainless steel, & I have a spare set of forks (reconditioned & repainted) ready to go on..
  18. NorcalBoy
    Very nice, Mr. Pete! Gaining on it.
  19. Laker
    Laker New Member
    Ontario
    Je-Sus Pete. That looks fantastic. Keep up the good work, I love the pics!
  20. Diving Pete
    As an update on rough costs so far for a bike that will end up as a ridable 8/10 - I could spend more time to get it to a 9 - But this is for me & life is too short...lol
    750 - Cost of unloved bike
    440 - Half system exhaust
    250 - Paint - for fairings, frame, engine, forks
    150 - Various other bits - SS bolts, brake pads etc, etc
    140 - Stickers (OEM copies - Rothmans style)
    80 - Powder coating front & rear wheels
    20 - Exhaust gasket
    180 - Chain / sprockets, new OEM exhaust bolts, new wheel bearings
    60 - Carb rebuild Kit
    40 - Service items - oil, oil filter, rad fluid.
    20 - Non oem carb mounting rubbers
    Still needed:
    Front & rear brake rebuild kits
    Front & rear master cylinder rebuild kits
    Front pads
    Might get new tyres - another 150 depends on how well it gets back together..
    So as you can see its still going to hit 2+k by me doing all the work... LOL, although at least 300 is in service items that need to be replaced at some point anyway. These are costs that add to every bike. If i wasn't restoring it to a 'reasonable level' then some of the costs could be ignored - but where's the fun in that.
