vfr700 carb synchronization springs.
Discussion in '1st & 2nd Generation 1983-1989' started by fatso1277, Jan 23, 2013.
  1. fatso1277
    fatso1277 New Member
    South Suburb IL.
    Okay back at it again...so i got carbs cleaned and no more leaks. WOOHOO!! now i was looking thru service manual and my carbs. looks like i mighta lost a spring. but not sure...how many synchronization springs should there be. i think i only have 5.
    Try fischin :fish2: in the parts diagrams to verify details. Flex the throttle shafts open and closed and check for any loose movment between. If you can move any throttle plate independently of the others, probably a missing spring. good luck:smile:
  3. fatso1277
    South Suburb IL.
    Thanks Squirrelman.
