VFR750 Chin spoiler hardware
Discussion in '1st & 2nd Generation 1983-1989' started by cbnj74, Mar 8, 2014.
  1. cbnj74
    cbnj74 New Member
    Does anyone know what size screws are used to mount the chin spoiler to the frame?
    It's the same hardware that is keeping your upper fairing on the bike. If original, they have collars so you can't over tighten and crack the plastic.
  3. cbnj74
    cbnj74 New Member
    Can you suggest a good source for replacement screws?
    Still available from Honda, but nearly 4 bucks each. You might check eBay for some used hardware. Sometimes there are auctions for a pile of hardware from a bike.
  5. artee
    artee New Member
    Rochdale,
    Wtf is a chin spoiler?
    Roger
  6. Allyance
    Allyance Member
    Germany
    East Bay, California
    You are talking about the little chin fairing on the lower radiator?
    Does it look like this:
    I just bought 6 to replace older ones, if this will work, I will send you some. You need 2 right? 6mm x 14mm
    Had mine off and on many times, but can't remember the hardware.
