vfr750 exhaust on a vfr700???
Discussion in '1st & 2nd Generation 1983-1989' started by huck731, Apr 11, 2011.
  1. huck731
    huck731 New Member
    wisconsin
    when I got my vfr700 last year the PO also gave me a 4-1 pipes with a sankei(???) slip-on that has been welded on from a vfr750, I believe that was an 86 or 87. Can I put this on my bike which currently has 4-2 cobra f1's (one or two of the rivets on each one are ripped off from my dumping it last year)??? or what woudl you suggest. I really want kerker k series, but I cant find it for my bike unless the slip-on would be just fine. the kerker uni would work also. basically I want to get a 4-1 on this bike if I can.
  2. TOE CUTTER
    Six of one and half dozen of another.......all the same. Custom tweaks may be a problem but the bikes are all the same from that point. Should bolt right up.
