Vfr750 fj '88 valve clearances
Discussion in '1st & 2nd Generation 1983-1989' started by Oakley_burn, Apr 12, 2011.
Tags:
  1. Oakley_burn
    Oakley_burn New Member
    Greetings all,
    Just wondering if anybody has the dimensions for the intake and exhaust valves for a '88 (FJ) VFR750? I've got a Haynes manual but i left it at work (idiot!) and am in the process of doing everything on the bike (valves, coolant, plugs, oil + chain)
    Any help would be appreciated.
    Phil
    Try in:.005"/ ex: .007" + or - 1mm.
  3. Oakley_burn
    as always the guru's at vfrworld answer once again.
    that's matched what i though it was from memory but wanted to check
  4. squirrelman
    OMG, huge mistake cuz i was in a rush !!!
    Should be + or - .001".......not 1mm.
