VFR800 VTEC 2003 wiring question
Discussion in 'Mechanics Garage' started by lygilco, Mar 26, 2014.
  1. lygilco
    lygilco New Member
    Hi Everyone,
    I have had the rhs cowling and headlights off for repairs and am now left with a loose connector. It originates in the instrument cluster. Can anyone tell me where it goes to? Imange attached S6301450.jpg
    Thanks in advance
    Murray
  2. skimad4x4
    France
    French Alps & London
    Looks rather like the open air temperature sensor which screws onto the underside of the upper cowl - dead centre between the headlights.
    Hope that helps
    SkiMad
  3. lygilco
    lygilco New Member
    Thanks - that is it.
    I just need to take the front cowl off again - godammit
  4. Allyance
    Allyance Member
    East Bay, California
    You might be able to get it in without taking everything off, push a fish wire through hole on underside of cowl, then attach to sensor, and try to get it to drop in. The wires on the sensor are on the short side, making it hard to hold cowl while connecting. I had mine on and off so many times working on LED headlights, I lengthened wires! Another hint, put a towel or pad across top of fender, cowl will drop down and scratch it!
