vfr800 vtec 2003
Discussion in 'Introductions' started by maltaplas, Apr 7, 2007.
  1. maltaplas
    maltaplas New Member
    I recently took my bike to have an alarm fitted in the meantime the battery went down so it was removed and charged then replaced after which no way will it start.Can someone help.
    Chris
  2. David02VFR
    David02VFR New Member
    San Jose, Ca
    does it crank over? if so, use a voltmeter to see what the volts drop to when you crank the engine over.
  3. deepdish
    deepdish Banned
    check ground is alarm always on??
  4. 02 VFR Rider
    02 VFR Rider New Member
    sounds like the alarm is keeping you from starting it
