Hi, My VFR800 01 water pump is leaking from the inspection hole. Can I rebuild it or should I replace the water pump as an assembly like Honda recommend? Thanks, Yotam
replacement is best...... rebuild is difficult work, and you need EXACTLY the right parts and use of a hydraulic press. so in one day you moved from israel to germany ?? what's that about ?
Hi, Just notice the comment "so in one day you moved from israel to germany ?? what's that about ?" it is my VPN ;-) Thank you for the tip!
