vfr800fw uk model
Discussion in 'Introductions' started by max, Jul 10, 2006.
  1. max
    max New Member
    why is the gear box so clunkey
  2. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    Check your chain tension to make sure it isnt too tight or too loose. I had mine adjusted just a tad bit tight and it sounded like 1st and 2nd were clunking. My chain is stretched defferently along the chain and I have a chain and sprocket set coming from Vortex. I will keep the 16 toth up front but will be going to a 45 tooth on the rear.
  3. max
    max New Member
    vfr 800fw uk model
    has anyone had problems with the variable valve intake ?
    i had a problem with my clutch switch which i renewed
    i notice after doing the checks that the variable valve solenoid keeps switching on and off with clutch lever [ neutral light out ]
    does anyone know if this is normal
  4. Rogue
    Rogue New Member
    Eh ?
    What is the variable valve intake and why does it have a solenoid ?:confused:
  5. RVFR
    hmm not much help for the Vtec thingy, but the clunck? is that when you drop it in gear from the first time? or when you shift during a ride. most will have a defite drop in place when going into gear from netrual, no biggy IMO
