Voltmeter install tips
Discussion in 'Mechanics Garage' started by samboss260, Mar 16, 2013.
  1. samboss260
    samboss260 New Member
    Brisbane
    Seeking some advice on those who have installed a voltmeter.
    I've got a marine analogue gauge coming, and will be installing it up on the front fairing.
    What is the best way to wire this up?
    Details and specifics welcomed. I'm not the most technical guy, but my mate is and he will be helping me, so I'll pass this onto him.
    Cheers
  2. zoom-zoom
    zoom-zoom Member
    BC, Canada
    Check out this link. I used it as a guide when I did the voltmeter install on my Datel meter last year. I think post #20 has a good wiring diagram showing how to wire the gauge with the use of a relay so that it cuts power to the gauge when the bike is off. I have a digital gauge on my bike that draws very little power and I could have wired direct to the battery but I wanted the added insurance.
    Lascar Voltmeter Install Pics - Electrical - VFR Discussion
  3. mello dude
    Romania
    Here's another voltmeter thread...
    Waterproof Volt meter - Electrical - VFR Discussion
    Wiring wise, the best wire route is down the left side of the bike, just follow the stock harness. Then no matter how you wire it, you should add a fuseblock to the positive side of the battery. Some guys power a relay from the rear taillight so the voltmeter is power on by the key. The other alternate is to have a switch to directly turn the voltmeter on/off. I went this route, (pics in the Lascar thread) because I like to check the battery before I power the bike up. My switch is under the seat, but with the attached thread, there is tons of creativity on ideas of which way to go.
    Hope this helps.
    :cool:
  4. wildstang
    wildstang New Member
  5. Dainius_M
    Dainius_M New Member
    Lithuania
    Lithuania
    I found great place for Datel voltmeter, As others have installed place (searched on the Internet) I did not like.
    Bad picture but in few days I will take in good quality.
  6. samboss260
    Brisbane
    Yeah, I've got the position sorted, just need wiring, install advie.
  7. mello dude
    Romania
  8. Mohawk
    Mohawk New Member
    Bristol
    Found this & bought one to put on my other bike (ZZR250) If I'd seen this earlier I would have added it to my 5th Gen too.
    Ebay item 150479033981
