VTEC Change Difference?
Discussion in '6th Generation 2002-2013' started by bunghole, Jun 17, 2009.
  1. bunghole
    bunghole New Member
    How big of a difference is there between the '02-'05s and the '06 + ?
    My understanding is that Honda adjusted the RPM thresholds for the VTEC engagement. I was wondering if the difference was significant pre and post and how much I should factor the difference into my bike buying decision.
    TIA!!
  2. Ghost_Rider
    Ghost_Rider Active Member
    LA & Utah
  3. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    It's not a huge difference and the VTEC is just as annoying in the early 6th Gens as it is in the later 6th Gens like mine (07) :wink:
    The actual RPM difference in engagement if I remember correctly is 6800 rpm on the older models and 6400 on the newer models. The newer models are slightly better since it is less likely to engage/disengage at highway cruising speeds but nonetheless I wish the newer models didn't have the VTEC at all.
    Regards,
    Rollin
