Water temp...third gen
Discussion in 'Mechanics Garage' started by rngdng, Jan 30, 2008.
  1. rngdng
    rngdng New Member
    Goose Creek, SC
    Hey guys, I don't have the stock gauges on my bike, but DO have a temp gauge which has programmable warning and danger lights. My problem is that I can't find actual numerical temperatures to program in. The service manual doesn't list such things, nor does the owner's manual.
    What should be considered a warning level, and what should be considered dangerous? Also, is it fairly normal for a VFR to reach 210 and activate the fan at a stoplight with air temperature at about 60F?
    Thanks,
    Lane
    the main overheating danger on a VFR is from a failed temperature switch that turns on fan, and this is a common fault.
    maybe set warning light at around 220 or so?????
    engine thermostat begins to open at 190 degrees.
  3. rngdng
    rngdng New Member
    Goose Creek, SC
    My fan comes on about 210 according to this Trailtech Vapor computer. I guess setting the warning to 220 and the danger to 230 might be OK?
    Lane
  4. squirrelman
    i was thinking that any temp much over the fan-turn-on setting (210 or above) would need your attention.
  5. rngdng
    rngdng New Member
    Goose Creek, SC
    OK, one more question. How often does your fan turn on at stoplights? Is it unusual?
    Thanks,
    Lane
  6. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    The 93 (I used to have) and the 97 both turned on alot at lights if I get stuck in stop and go traffic, and it doesn't have to be very long. Sometimes in the summer three stoplights is all it takes.
    Sometimes I think the 97 runs a little hotter.
    Then down the road I go and it cools down again.
    BZ
  7. rngdng
    rngdng New Member
    Goose Creek, SC
    Thanks, that what I wanted to know. I'll reset my alarm setpoints to something more realistic!
    Lane
