weird deep ticking on startup
Discussion in 'Mechanics Garage' started by Evan A, Aug 9, 2023.
  1. Evan A
    Evan A New Member
    hey yall i seem to got some weird tick on startup on my 2004 vfr 800, however its only when i take it above 4k rpm. it also goes away as soon as i hit 80 degrees Celsius. ive listened to almost every other video of ticking noises but nothing really sounds like this. any advice or opinion would be greatly appreciated.
    https://youtube.com/shorts/ws7x7-7pE9Y?feature=share
    i hear puffing more than knocking so could front header bolts be loose with a leaking exhaust gasket cuz it sounds kinda like that ?
  3. Grum
    Grum New Member
    Have a close listen for the noise/clatter up at the R/H side cylinder head covers, front and rear. This is generally where failing CCT (Cam Chain Tensioner) noise can be heard.
    How many miles has it done and have either front or rear CCT's ever been replaced?
  4. Evan A
    Evan A New Member
    wicked thanks guys, ill check the cct and the exaust gasket tonight. im a little under 40k miles so i wouldnt be suprised if the ccts needed changing
  5. bmart
    bmart Insider
    Charlotte, NC
    My CB-1 sounds a bit like this and has an exhaust leak at the header connection since...dinosaurs.
  6. ridervfr
    Belgium
    sounds like an exhaust leak to me.
  7. 34468 Randy
    I have a similar sound that goes away once the bike heats up. I believe the exhaust gasket, which looks like steel wool actually, but probably some other material, has finally burned out. I had changed the exhaust a long time ago and re-used the gasket even though it was looking thin at that time. I have a new gasket and will be taking care of that along with several other things soon as the weather cools down a bit. Insurance runs out end of the month anyway.
  8. Evan A
    Evan A New Member
    Ok so I got gaskets on order and if not that I think I’ll just get a pair of manual chain tensioners. Thanks for all help guys I really appreciate it
  9. Grum
    Grum New Member
    Choice is yours, but strongly recommend you fit new OEM CCT's and stay away from the manual type!
