Weird Rattle
Discussion in 'Mechanics Garage' started by NineFingerTommy, Oct 30, 2015.
  1. NineFingerTommy
    NineFingerTommy New Member
    Indianapolis, IN USA
    My bike has developed a rattle from the engine/clutch/somewhere. Nothing at idle. It was mostly doing it when I would be slowing down. I would let off the gas and get quite a loud rattle. Pull in the clutch rattle would go away. I don't believe it is the CCT since it goes away when the clutch is pulled and doesn't make the noise all the time.
    The bike has now also started to get a bit of the same rattle under acceleration too.
    Clutch? CCT? Chain? I am lost.
    2007 VTEC. 30,000mi/48000km
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    30,000 miles on original CCT's, I am going with CCT's.
  3. NineFingerTommy
    I am not sure what all service has been done. I bought it in March with 24k on it.
  4. squirrelman
    Time to do a proper synchro job on the throttle plates to smooth it out. Rattle is most likely clutch plates rattling within the basket due to poor synch.
  5. Scubalong
    I would check the chain first and then move to the CCT.
    My dime is the chain :juggle:
  6. 34468 Randy
    I am with Long for starters. A sloppy chain can cause rattling similar to what you described. If it is original chain, it would be over due by now. But you also get weird rattling noised from CCT. I think your mileage is a little low for that to develop yet but who knows. Check to make sure there are no pop cans tied to the back of your bike.:joker:
  7. rjgti
    rjgti New Member
    regina sk
    all good ideas guys, hope he can use a stethoscope to pin point it
  8. rhoderage
    rhoderage New Member
    Nova Scotia
    I had the same sound and vibes, it was the chain. Replaced, good to go. sprocketcenter.com is a reasonable online vendor
  9. 34468 Randy
    Yup. That is where I've bought most of mine. They have always has about the cheapest DID chain and sprockets I have found.
  10. squirrelman
    If the OP knows he's riding on the original chain he should replace it, as few-to-no OEM chains are still OK at 30K.
  11. NineFingerTommy
    Thanks for the advice guys. It was the chain.
  12. duccmann
    Hopefully your name doesn't have anything to do with the chain....glad ya figured it out
  13. NineFingerTommy
    haha. no. That was a lawnmower incident at a young age.
  14. duccmann
    Thank God
