Wet or dry torque specs...
Discussion in 'Mechanics Garage' started by DPS, Oct 25, 2025.
  1. DPS
    DPS New Member
    In a previous thread a lot of you helped out with information on torque specs for the crank case cover on my VFR. Thanks.
    When I wondered why all of the guys that posted videos on bike repair they didn't use anti-seize on the bolts. I searched the net and found this link to an article in Cycle World talks about wet and dry torque specs. I also recall someone saying when following torque specs from a given service manual to assume they are dry torque specs and unless otherwise specified you do not use a thread locker, anti-seize paste or oil because that changes the dynamics of the torque necessary to hold two parts together.
    Additionally, if you feel compelled to use a thread locker, anti seize paste, etc. it is recommended to reduce the torque value by 25% then torque.
    What do you guys say?
    www.cycleworld.com/2014/07/25/ask-kevin-if-i-lubricate-threads-or-use-a-threadlocker-should-i-reduce-the-tightening-torque/
  2. mello dude
    NO!
