What a Difference !!!! I added slick50 to my ..
Discussion in 'Anything Goes' started by emptyskull, Nov 12, 2008.
  1. emptyskull
    emptyskull New Member
    near the bat cave
    I added slick50 to my bike and wow!! what a difference......It seems to have more power and a quieter engine, and runs cooler..I put 1 and 1 half quarts (slick50)with 2 n 1 half of synthetic oil (synthetic is the best period.) top gear roll on it pulls smoother, first and second gear just rips through the rpms. It is almost like I put an after market exhuast and comp on it whoa !!!So far I only have gone about 120 miles but no problems and the oil looks super clean through the site window. Wow !! wish I have done this sooner seems like a different bike....:cheersaf:
  2. mello dude
    Romania
    Are you serious? Save your pennies for a clutch job! :kaboom:
    MD
    (unbelievable!)
  3. two4one
    two4one New Member
    Mohrsville, PA
    :rolleyes:
  4. emptyskull
    near the bat cave
    why would I need a clucth??? I was reading that zmax would also help out the engine by soaking into the metal. It states that you don't need to drain oil just add and it soaks in. I am adding this also after about another 100 miles zmax should have soaked it in more if it works like slick50 maybe I'll get another 5 hp.. awesome !! I have seen a product called engine oil boast it adds 5hp to most cars so this weekend I am going to add this after zmax is soaked in. I might end up with 15 hp over stock by running all the additives and my engine should last twice as long awesome...next thing is to try the high output spark plugs 5hp with those too!!I am going to do that this weekend with the oil boast..I will end up with almost 15-20 extra hp over stock sweet...:cheersaf:
  5. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    It's official, we have a new version of elf800.
    But instaed of personal insults; this version spouts mechanical insults.
    I think VFRW is about to get interesting again:)
    OR it could be empty's sense of humor does not translate well over the net.
    BZ
  6. VT Viffer
    VT Viffer New Member
    South Carolina
    Took everything the snake-oil salesman said at face value, huh?
    All of the horsepower claims that these products make are fictitious for the most part. If you have a filthy engine (internally) then one of these "cleaner" products might increase your horsepoer level back to stock levels by cleaning out your engine.
    You will probably need new clutch frinction plates at the end of this "experiment" because the clutch is a wet-type. This means that it is immersed in and shares the oil that lubricates everything in the engine. By adding something that makes the oil "more slippery" you are decreasing the amount of friction that the plates can provide. This in turn means that the clutch is gonna slip more and burn up faster.
    BTW - there is no such thing as a "high output spark plug". The size of the spark is determined by the coil.
  7. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    The :bs:is getting deep in here.
  8. kingsley
    kingsley New Member
    Osoyoos, B.C. Canada
    LMAO !! That thing will be putting out 200hp before long!!
  9. Britt
    Britt New Member
    Westmont, IL
    I put Slick 50 in my lawnmower engine and it developed so much extra power it pulled my grass right out of the ground, roots and all!
    Anyone know a cheap source for sod?
  10. derstuka
    San Diego, CA
    Tim Allen would be proud!
    I heard that if you put Mrs Butterworth Syrup in the coolant it drops the temp 20 degrees and boost your HP by 10! Try it out emtpyskull.
  11. vfourbear
    vfourbear New Member
    Louisville, KY - Under my tinfoil hat
    I've been putting Slick 50 in my protein shake every morning, I am now faster than Usain Bolt
  12. Longerfellow
    Longerfellow New Member
    Pollock Pines, CA
    I love a thread with that "trainwreck" sort of attraction!
  13. RVFR
    This is going to get good. I guess if he feels that it's working for him, who's to argue the point, it's his bike, shall be interesting. As far as the clutch goes I've always wondered as the synthetic being more slippery why it doesn't do em in sooner, so just maybe the slick50 won't do any more harm, unless you drag race. But anyone that believes changing the oil gives you more Hps well is,,, hey I have an island in the Caribbean for sale at a great price.. I'm sure you can tell the diff, one can easily tell the diff if one was using Dino oil then switch to Amsoil. but there's not more hp. just a better response which can be felt as an increase in Hp. So on this lawn mower thing I need a yard cleaned up big time...
  14. NorcalBoy
    Now just remove your centerstand.........
  15. drewl
    drewl Insider
    Virginia Beach, Va
    Wee Haw, off we go flying through the trees with the lights off.
  16. bluespecv03
    bluespecv03 New Member
    Daytona Beach, FL
    And I quote my response to his last post...
    Really? Are you serious?
    Good choice of user name, OP.
  17. Nungboy
    Nungboy New Member
    Tucson, AZ
    I haven't laughed this much since that 'scary girlfriend posing with the car' thread the other day.
    THANKS KIDS!!!
  18. powerslave
    powerslave New Member
    winnipeg,manitoba.
    :smow:What an awesome winter thread:cheersaf:
    Last year we were Hating Harley-Da@#$son,
    This year we're puttin stupid shit into our crank cases!:hangme:
    This place rules!!!!!:strong:
  19. drewl
    drewl Insider
    Virginia Beach, Va
    Hey, by the way...Who hates Harley Davidsons?
  20. steven113
    steven113 New Member
    Pensacola FL
    my advice to you emptyskull is to drain your oil now and replace it with a quality synthetic advised for the bike(That is if you have not already comitted HARRY KARRY by now). You are getting no real gains from adding slick 50 or any other additive in your crankcase. The oil companys spend millions if not billions of dollars every year to develop the best oils known to man, do you really think that they would overlook an additive that would make their product better without buying the rights to it and putting it in their product already on the shelf?
