What are you using for bike stands? How do you secure in truck?
Discussion in '5th Generation 1998-2001' started by Guy Cole, Oct 11, 2021.
Tags:
  1. Guy Cole
    Guy Cole New Member
    Silicon Valley, USA
    It's time for me to change tires on my gen5. Please let me know your fave stands.
    Also, how do you transport your bike? I don't see any obvious attach that will not rub the plastics.
    Thank you
  2. ridervfr
    Belgium
    Woodcraft front end stand, I have a Lockhart rear stand that I had for close to 30 years. You can get a Canyon Dancer front end set up where it goes around the hand grips and you run your ratchet straps from there (this way it clears the body work) In the rear you can use the grab rails possibly or the rear passenger foot pegs. Also for the front you can go to the left right side of the wheel and use the hook from the ratchet strap under the lower triple tree. This set up works with any bike.
  3. Terry Smith
    New Zealand
    IMG_1032.JPG I used a jack to elevate the front end then a block of wood under the headers to support the bike (my jack has an annoying slow leak).
  4. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I have a convertible front Pitbull stand, but if I don't feel like digging it out of the shed, I'll use a small jack under the motor and some weight on the back end to keep the front up. Doesn't take much to raise the front until the rear tire touches. That gives you enough room to change the tire.
    For traveling I use a Condor chock. I have the Canyon Dancer for the front, but they are only snug. I strap the back down fairly firmly and it doesn't go anywhere. The nice thing about the Condor chock, and others like it, is that you can hop off the bike when it's in place. Pretty secure until you get it tied down.
  5. raYzerman
    raYzerman Member
    Millgrove, ON
    When on a trailer or truck, need to keep the front wheel in place.... I use Harbor Freight wheel chocks that have a tie-down point on each side, but for a bike with no attach points, I use a Canyon Dancer on the handlebars and tied down wider, i.e, at the corners of the truck box. No need to overtighten the straps, just compress the suspension slightly. One can also put a tiedown around the lower triple tree to each of the HF tiedown points... I haven't done it on a VFR, so can't tell you if the straps clear the fender... they should.
    At the rear, no need to tie "down" per se, only need to wrap a tie strap around the rear wheel to keep it from going sideways.... tied down at the back corners of the box.
    ridervfr likes this.
  6. Gator
    Gator Insider
    I simply do what Terry does. I have Pitt Bull stands for the CBR that are rock solid and I have used at the track for over 15 years.
    cbviffer likes this.
  7. bk94si
    bk94si Member
    In the garage I have a pitbull for the rear and a cheap ebay stand for the front that lifts from the triple. In the trailer, I have a Harbor Freight chock and I use a canyon dancer for the front and a generic ratcheting tie down for the rear.
  8. Guy Cole
    Guy Cole New Member
    Silicon Valley, USA
    Thank you everybody. I honestly had never heard of these produces, i.e. "canyon dancer", etc. Your advice was a big help.
  9. Cherryriver
    Cherryriver New Member
    SW Chicagoland
    We have a Condor front wheel chock that I use in three modes: bolted to a trailer, free on the garage floor for a drive-in grab, and bolted to the Harbor Freight lift (where it spends most of its time).
    Not cheap, but top-level quality and excellent design.
    I have some reservations about the Canyon Dancer tie downs, even though I've used them plenty in the old days.
    Our friend the service manager at our long-time Honda dealer tells us that they discontinued the use of them after having several handlebars break when the trailer hits a hard bump. Only the secondary, rear, tie downs saved those bikes, but it was still very expensive for them.
  10. Gator
    Gator Insider
    I have an old Canyon Dancer but have not used it since I found Cycle Cinch tie downs. I think the problem with these type tie downs it you do have to strap them down and compress the suspension some. Over tight leaves no room for the suspension to work and hard bumps on the trailer transfer a load straight to the handle bars. Use the Pitbull system on my trailer for the track bike, super easy and you do not have to compress the suspension. I do use 2 straps as a just in case backup.
  11. Gator
    Gator Insider
    PS, the original Cycle Cynch straps from about 15 years ago had a few buckles that would break. I contacted the manufacturer and he sent me brand new ones with their redesigned buckle, they are rock solid.
