What is normal running temperature and when should the fan go on?
Discussion in '1st & 2nd Generation 1983-1989' started by VFRfrom818, May 7, 2012.
  1. VFRfrom818
    VFRfrom818 New Member
    I have a 1986 700 that I am slowly putting back together. I just changed the radiator and it seems to be holding, but I am not sure what the running temperature should be. I rode the bike today and the needle moved about a 1/3 of the way and stayed there. Is this normal running temp? I kind of assumed it should sit in the center/middle of the temp gauge.?
    Also, last night I was trying to get the fan to turn on, so I let the bike sit running. The needle got past middle/center and worked it's way up to 3/4, but no fan. ??
    I know the fan is good cause it was working with the old radiator. I'm guessing I didn't connect it correctly. Perhaps I need a new sensor?
    Thanks.
  2. tinkerinWstuff
    the fan switch, screwed into the radiator, completes the ground circuit allowing the fan to come on. Take a jumper wire connected to ground and touch it to the wire that goes to the switch in the radiator and see if the fan will come on.
  3. VFRfrom818
    Excellent idea. Thanks. I also read on another post that these bikes generally run "hot". Is this true?
    Someone also recommended using something other than anti-freeze. What would you recommend? I live in So. Cali and summer is comming.
  4. tinkerinWstuff
    Water Wetter is the popular alternative to Anti-freeze for more efficient heat transfer.
  5. squirrelman
    Normal temp=1/3 scale Stop and go traffic on a hot day=3/4 scale, and fan should switch on.
    The thermoswitch is not reliable, so consider setting up a manual switch wired in parallel with it so you have positive control of your cooling fan at all times.
    If you anticipate traffic slow-downs and activate your fan before the thermoswitch kicks in, the engine will stay cooler.
  6. paradox11235
    paradox11235 New Member
    Colorado Springs, CO
    I don't think mine even gets up to 1/3... Maybe my thermostat is stuck open?
  7. VFRfrom818
    I've been running the bike now for a few days, and in traffic, she stays about 1/3. Once I get to stop and go traffic, it does climp half way. I just put all the fairings back on, so let's see how she performs. I will consider the Water Wetter and the direct switch on the fan. Thanks guys.!!
