What is the speedo drive hub made of?
Discussion in '3rd & 4th Generation 1990-1997' started by jethro, Oct 22, 2020.
  1. jethro
    jethro New Member
    Parkville, Mo.
    Can someone tell me what the speedo drive hub that connects to the bolt head that holds the countershaft sprocket on and runs the speedo drive. Is it steel or aluminum? I really didn't want to remove all that stuff to find out. Figured someone here would know.
    on gen 4, it's...................................plastic. :eek:
  3. jethro
    jethro New Member
    Parkville, Mo.
    I didn't even think of plastic or to mention what gen I had. Mines a 3rd gen and I just kind of figured it was made of steel and I saw some made of aluminum which would be lighter.
  4. COS_VFR
    COS_VFR New Member
    Romania
    Partzilla shows the same Part Number for 3rd and 4th gen.
  5. mello dude
    Magnet?
  6. NorcalBoy
    S-Man nailed it, they are plastic. That part is used on almost 700 different Honda models.
  7. raYzerman
    raYzerman Member
    Millgrove, ON
    I'd think plastic was safest... I've seen many cables rusted/seized just a few inches up... regular cable lube would let it turn easy and might keep the plastic from wearing out.
  8. duccmann
    66k on my 6G
    Replaced once
    Plastic as well
  9. OOTV
    OOTV Member
    I had found and purchased an aluminum one but it didn't do any better than the plastic one IMO. I went back to the OEM plastic ones as they are cheaper and readily available.
