What is the weight limit
Discussion in '7th Generation 2010-Present' started by E.SLC., Aug 28, 2014.
  1. E.SLC.
    E.SLC. New Member
    Utah
    What is the weight limit on a 2010 VFR 1200 riding two up safely?
  2. Scubalong
    400lbs max
    If the weight more than 400lbs replace heavy spring and pumb up your preload.
    Loose some of the weight from riders strongly recomended :pound:
    Hope this help.
  3. E.SLC.
    E.SLC. New Member
    Utah
    Thank you Scuba. We are close to the max limit.... 350 combined.
  4. Scubalong
    You guys will be fine :thumb:
    Change the forks oil to heavy grade and adjust your preload to the max and you two good to go.
    Ride safe
  5. TOE CUTTER
    This thread reminds me how much I like fat chicks.
