what is this part? pic included
Discussion in 'Mechanics Garage' started by supervfr, Nov 12, 2008.
  1. supervfr
    supervfr Banned
    the gold jet lookin parts
  2. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    Based on its location, I would guess that it is the float bowl vent or the air passage that is part of the idle circuit. Just a guess, though.
  3. jev.
    jev. over there
    Not sure what they are, but the parts fiche doesn't show them so they're not replaceable.
  4. VT Viffer
    VT Viffer New Member
    South Carolina
    Do they have a hex head on them or are they round?
  5. supervfr
    supervfr Banned
    Their round. they pull right out of the carb. about a centimeter long.
  6. squirrelman
    force some liquid or air through the hole and see where it exits
  7. emptyskull
    emptyskull New Member
    near the bat cave
    wonder if that has to do with the air screw? not sure they just pull out and are only a centimeter long?? bet she was disapointed..
  8. vfourbear
    vfourbear New Member
    Louisville, KY - Under my tinfoil hat
    I would say float bowl vent or fast idle jet?
  9. supervfr
    supervfr Banned
    mine pulled right now. with pliers perhaps since they were in for 22 years. but just pulled out fairly easily.
  10. Seidts
    Seidts New Member
    Southern Vermont
    That is the slick50 injection port!
  11. Maggot
    Maggot New Member
    Park Ridge, IL
    Sorry my only carb experience is old CB 750 carbs but spray some aerosol Gumout thru there using the extension straw. It won't hurt a thing, you'll clean out the passage and you will find out where it goes. I agree with Squirrelman it probably vents the float bowls and if there is any varnish in there it will do a world of good.
    While your in there use the Gumout in all passages. I drove the same CB 750 for 32 years and would clean the carbs every three or four years. Gumout was my best friend. Every time I cleaned the carbs the bike ran smooth as silk especially at idle.
  12. kia001
    kia001 New Member
    air corrector jet, common on the rear of the bell housings on CV carbs
  13. drewl
    drewl Insider
    Virginia Beach, Va
    I'm Drewl, and I disapprove of Jev's new avatar.
