What model are these from?
Discussion in 'General VFR Discussions' started by spyderbret, Sep 13, 2009.
  1. spyderbret
    spyderbret New Member
    Las Vegas NV.
    As you may or may not know, I am cleaning up and restoring a 87 VFR700F2.
    It has been through a few different owners and had a number of modifications done. Take a look at the pictures below and see if you recognize what model they are from. Should I replace them with stock parts? If they work good I would like to keep them...
    I appreciate any help you can give.
    Tripple Tree:
    Front Wheel and Shocks:
    Rear Wheel:
    Rear Swingarm:
    Thanks again!!
  2. deepdish
    deepdish Banned
    4th gen ?..................
  3. squirrelman
    Upper clamp from CBR or gen 3 or 4 VFR
    wheels from CBR 600F 3??
    stock forks
    crudely and unnecessarily modified stock swingarm with horribly ugly welds
  4. TOE CUTTER
    Gen 3
    It is the same one on my gen 2....Squirrel nailed it....would guess hawk as VFR was not black.:thumbsup:
  5. squirrelman
    .....can't be Hawk cuz it's missing the 2 attachment points at front edge where gauges mount....unless they were ground off?
    If it's Hawk it's a 1990 model identified by Honda logo cast in.
  6. spyderbret
    Las Vegas NV.
    Cool. Good info guys. Thanks.
    I like the wheels but I am going to replace the rotors. Do I need to specifiy CBR rotors or are they the same as the VFR?
    The upper clamp is fine with me. I like it. I will just paint it and clean it up. I have to buy a new ignition as well since the original is gone and the previous owner bought some piece of crap. Are the ignitions pretty much the same or do I need one that will fit this clamp?
    I have two choices with the swingarm. One, get it cleaned up and either powdercoat it or paint it so it does not look so bad, or get a new one. It is my understanding it was a track bike for a while, hence the additional stuff. Thoughts or opinions?
    TIA!! :thumbsup:
  7. TOE CUTTER
    Logo
    I based my guess off the black backround on the Honda logo as it was clear of VFR.
  8. Richard Thompson
    Richard Thompson New Member
    Auckland, New Zealand, New Zealand
    OMG that swing arm is a piece of work....
    there oughta be a law against doin that to an innocent motorcycle part
  9. squirrelman
    ""I like the wheels but I am going to replace the rotors. Do I need to specifiy CBR rotors or are they the same as the VFR?""
    Keep the stock rotors. Why would you want to replace them??
    New rotors from Honda run around $325 each !!
    CBR rotors may not work because of different diameter ( except that '88/'89 CBR F1--"Hurricane" --rotors were the SAME as VFR).
    You should be aware that special (not VFR) spacers may be necessary to properly fit those wheels.
  10. VT Viffer
    VT Viffer New Member
    South Carolina
    That upper triple is NOT a 4G piece.
  11. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    no the wheels are CBR F2's you can see where the speedo drive goes inot the wheel, see the two slots,id buy that front wheel off you?
