What the heck is this for?
Discussion in 'Mechanics Garage' started by geekonabike, Aug 27, 2013.
  1. geekonabike
    geekonabike New Member
    Ontario, GTA
    Hi folks, long time lurker here. My 2003 red VFR and I took a bit of tumble the other day. I took off
    the upper cowl since it's cracked and needs to be replaced. I've accounted for all the ends of the
    wiring harness except for this little connector below the fusebox.
    Can someone identify where the lower connector in the attached pic is suppose to go? Did I pull
    it out of the fusebox or something?
    Thanks.
  2. Scubalong
    :hss: about time you come out of the closet :rolleyes:
    Sorry for your mishaps :sad: I hope someone can chimp in shortly to help. Stoshmonster and Mr sleep should know well about electrical.
  3. Scubalong
    :welcome: to the madness :wave:
  4. NorcalBoy
    I believe that is the service connector for the PGMFI, when jumped you can determine a code number via FI light.....
  5. geekonabike
    Ontario, GTA
  6. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    NCB is correct. It should remain unconnected until you want to diagnose the codes stored by the ECU.
  7. geekonabike
    Ontario, GTA
    Sweet. Thanks.
  8. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Spare parts. Just cut it off. :)
  9. Scubalong
    Hehehe :pound:
  10. ftl900
    ftl900 New Member
    Las Vegas
    ...to save the extra weight, and lighten your bike.
  11. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    If you need any of the relays etc, just let me know as I have a box full and a spare harness in the garage that I can yank connectors off if necessary.
