What to look for when buying a Grn 5 VFR?
Discussion in '5th Generation 1998-2001' started by thelankyone, Sep 28, 2009.
  1. thelankyone
    thelankyone New Member
    Hey all,
    Looking to get a 5th gen. VFR in the near future and would like to find out what in particular I should be looking for when doing a pre-buy inspection? No matter what I will be taking the bike to a mechanic who is very familiar with these bikes (sidebar - any recommendations for a great VFR mech. in the Bay Area?) but I would like to tap into the knowledge base of this board to see if there were any things which would make you immediately walk away or be wary about a particular bike.
    Thanks all,
    Thelankyone
    P.S. Yes, I did try using the search funtion and wasn't able to get a pre-purchase list.
  2. e cabrera
    e cabrera New Member
    San Luis Potosi, MEXICO
    look to regulator/rectifier
    I suggest you take a look to the regulator/rectifier (R/R), because it is a common fail in honda's bikes, check if the 3 yellow wires are too hot and the plastic conector is ok not burned.
  3. Junyr
    Junyr New Member
    Des Moines, Iowa, United States
    Where's the location of these items on the bike?
    I'm soon going to be in the 5th Gen market and will keep this in mind when looking at potential purchaces.
  4. squirrelman
    Obviously you'd like to know if the bike's been down and if so how hard.
    Check handlebar ends for flattening or gouges and look at clutch cover on right and generator cover at left for marring, scratches. Check bodywork for looseness or scuffs.
  5. Junyr
    Junyr New Member
    Yeah, I knew the obvious stuff like that. I didn't quote the reply above mine and should have. What I was refereing to was the R/R componant locations.
