whats this part ?
Discussion in '1st & 2nd Generation 1983-1989' started by agfirecat, Apr 16, 2009.
  1. agfirecat
    agfirecat New Member
    does anyone know what or where this part goes i found it in with everything that came with my bike. im not even sure it goes to my bike its an 87 700.thanks for any info.
  2. nvoges
    nvoges New Member
    Columbus, OH
    Ummm......don't know if it belongs on your bike, but does that look like a vacumn canister of some type?
  3. crustyrider
    crustyrider New Member
    North Country, New York
    I'm with you.....does it show up in the service manual?
  4. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    Flux Capacitor that mounts to the lower left of the air intake Hyper tube system. Is a bitch to get at unless you have a Unarlin Socket and 4mm adapter.
  5. volks6000
    volks6000 New Member
    Jacksonville , Florida
    that's what i thought:rolleyes: it's where the tubes go in. just make sure you do 88.
  6. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    I can't tell how big it is by the picture, but it might be a vacuum controlled fuel shut-off. Lots of bikes in that time period would not allow gasoline to flow to the carbs unless the engine was running, or cranking over while starting.
    If the ports are too big for fuel lines, then I would guess it is the same sort of device for re-routing airflow depending on engine vacuum, as in smog control.
  7. kia001
    kia001 New Member
    It's for emmisions. It's part of the roll over fuel vapor system off the carburetors.
  8. crustyrider
    he said emmisions
  9. Ghost
    Ghost New Member
    Kernersville, NC
    I believe thats for a later model though.
    you will need minimum 1.21 gigawatts to power it. I have a food processor you can borrow for the mean time. What's your address? I'll send it to you.
    here is the earlier one..perhaps this one will fit your bike.
    http://www.instructables.com/id/Flux-Capacitor/
  10. squirrelman
    Just toss it in the dustbin...it's not from your VFR
  11. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    What it is is a diverter valve used for emissions. Does it have a part # on it I can tell you what its off of.
