WHEEL SPACER
Discussion in '1st & 2nd Generation 1983-1989' started by sean p, Nov 24, 2021.
  1. sean p
    sean p New Member
    Chesterfield-Derbyshire
    Morning all, nearly ready for getting the VFR rolling again but I`m a bit puzzled about the front wheel. Its been re powder coated and I`m just about to renew the bearings but I cant work out how the spacer that fits inside the wheel (between the bearings) fits. The manual refers to driving it home but that doesnt seem possible to me due to its design is it meant to fit between the bearings and then gets nipped up when the axle bolt is torqued up? Any thoughts greatly received.
    Thanks, Sean.
  2. Thumbs
    Thumbs Member
    Bath(ish)
    It just sits between the bearings, the Honda manual tells you which side to fit first, once the second bearing is in the spacer should be snug against it
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    The spacer should be pretty snug between the bearings, so there won't be much "nipping up" when the axle is tightened. :)
  4. RogueRC24
    Yeah, that front spacer literally just sits between the two bearings with slight compression. In the end, I always found a little less snug to be better than cranked on. The axle and axle nut will finish off the compression and your wheel should spin nice and freely with everything torqued. A little drag is ok (mostly from the calipers and pads), but too much drag is an issue in my book and might be misalignment.
  5. sean p
    sean p New Member
    Cheers chaps all back together and spinning freely.:)
