Wheel tape/stickers anyone???
Discussion in '6th Generation 2002-2013' started by killerkingdon, Aug 23, 2008.
  1. killerkingdon
    killerkingdon New Member
    Arkadelphia
    I am thinking about either a burgandy red or a white wheel tape to put on the VFR. I can not seem to find many pictures (if any) of anyone who has already done this. Just thought someone could post a pick before I waste another 15 bucks @ dennis kirk...also...tell me what color you think would look best on the white bike with gray wheels...
  2. 34468 Randy
    If you do so, make sure yon post up. I also have a pearl and was thinking of possibly doing the same. But I will let you spend the money first. After all, I do have Scottish blood running in my veins.
  3. Cyborg
    Cyborg New Member
    Have you tried Tapeworks?
  4. Big3
    Big3 New Member
    Lancaster, Ohio
    the following is Not my work ... I borrowed it from a 600 cbr forum
    but it does work :)
    My first writeup, so chill out if I make some mistakes. I'm also fully aware that this isn't the wheel of an RR. Mine's out getting new fork seals, so we'll use my dad's HD Softail.
    Ok. I didn't want to pay for a stupid plastic applicator, nor did I want 7mm stripes. I got my stripes from Canadian Tire. They're 1/8". The applicator isn't pretty... but hot damn it works.
    You will need:
    - Thin plastic sheet. (I used the front cover on a notebook... school's out.)
    - Duct tape
    - X-Acto knife
    - Pinstripe tape
    - Cardboard
    - Scissors
    - Rear and Front stands will help lots, but they're not totally necessary. You'll just have to stop and roll the bike.
    Before you guys do any of this, clean your rims! Spring is messy. Get all oil, chain lube, and grime off with soap and water, then clean the lips with rubbing alcohol.
    Here's a pic of the 1/8" pinstriping tape. It came in a whole lot of colors. Cost $5.
    This is the kind of thin plastic I was talking about. Clear plastic helps you to see where the tape is being positioned under the applicator.
    Cut a section off of the cover. A section 1.5" by 1.5" is about the size you're looking for.
    Now trim one side of your plastic piece to match the countour of your rim.
    Now cut some cardboard strips, and fold them in half. You're looking to get a thickness of 3/8" to 1/2".
    Now it's time to mock up your wheel striping rig. Sandwich everything together (cardboard layers and plastic) with the plastic layer on top. The goal is to have the cardboard resting on the top of the rim, and the plastic covering the face we're applying the stripes to. In this picture, I have marked with a pen exactly WHERE on the rim I'd like the stripes to be applied.
    Now that you've successfully mocked up your applicator, make sure your layers don't slide around... or your stripe won't go where you wanted it to. Carefully tape everything together. It should look like this:
    Now we'll cut a hole with an X-Acto knife to pass the striping tape through. My tape is 1/8", but I cut my square JUST barely wider than the tape. Too wide will allow the tape to wander, and too skinny will pinch and ripple the tape.
    Now you're just about ready to apply the tape. When you pass the tape through the applicator, do not also pass through the paper backing. Only the tape itself (adhesive exposed) should be passing through the tiny square you just cut out. Like so:
    This is where your hands should be when applying the tape. Left hand keeping the rig on the topside of the rim, left index finger applying gentle pressure to the tape as it is being layed down on the outer face of the rim. It helps to pull the paper backing away as it is fed into the applicator. A steady controlled motion around the rim will give you a smooth straight finish.
    ALMOST done. This last step will help ensure your tape overlaps seamlessly when the two ends meet. Before the ends overlap, trim 1 to 2 inches off the end you first layed down. This first 1 or 2 inches isn't always straight as you're just getting a feel for the tape.
    That's it guys. Hope this has helped a few of you. Be patient. I didn't get it perfectly the first time. I know there's a few of you out there looking for wheel stripe help.
  5. Big3
    Big3 New Member
    Lancaster, Ohio
    too add
    if you cut the cardboard to match the other part of the wheel you could just run the cardboard around the "inner" part of the wheel for a better guide <---- make sense?
  6. 34468 Randy
    Good Stuff,
    I didn't know they had Canadian Tire down there! You should patent that tool you devised before Canadian Tire does. Could be some easy money for you. Matter of fact, I am off to Cdn Tire now
  7. Big3
    Big3 New Member
    Lancaster, Ohio
    seems you missed the first part of my post
  8. 34468 Randy
    Go Patent that make shift tool anyways. Then you can tell me where to go cause you will sure as hell be a lot richer than me LOL
  9. killerkingdon
    Arkadelphia
    Nice little write up....Looks like Im off to cut up some cardboard...
