when turning at moderate speed when i downshift it jumps sideways
Discussion in '3rd & 4th Generation 1990-1997' started by love4vfr, Mar 18, 2008.
  1. love4vfr
    love4vfr New Member
    dallas tx
    I dont know why but when i'm downshifting in a turn the rear end seems to jump sidewayz its not a good feeling , the tire pressure is good and the tires are new , anyone know why it would do this??
  2. mello dude
    Romania
    Do you pull the clutch in a second and blip the throttle and match engine speed to the gears, then release the clutch when you downshift? Or - just pull the clutch in and click down a gear and let the clutch go?
    MD
  3. squirrelman
    Downshifting should be done before a turn, NEVER in a turn.
    Carefully and skillfully matching rear wheel speed with engine speed (through the clutch) is an essential riding skill and will minimize the problem you describe.
    The proper speed for a turn should be set before turning in, based upon your experienced judgement of several factors, and turns should be ridden with a neutral throttle or, better, with slight increase in throttle through the turn.
    Find and study a copy of Kieth Code's book "A Twist of the Wrist" for additional info.
  4. RVFR
    My question too. Sounds like you need to match engine speed to the gear your going to be in was my first thought. yea changing gears mid corner is tricky anyway, so unless there's a major reason to do so, do it before or after the turn. besides the VFR has good mid and low range torque, so plow through the turn.
  5. yoda6669
    yoda6669 New Member
    Georgetown, TX
    The same thing happened to me last Sunday. It scared me the sh@@ out. I tough I was going to fall from the bike. It's been like 11 years since the last time I rode a bike, so I'm real rusty. Anyway I'll never do that again, from Sunday foward I'll downshift before the curb.
  6. squirrelman
    Downshifting before a curve should be done while bike and wheels are running straight ahead and before leaning into turn.
  7. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    I second some reading on Twist of the Wrist!
  8. SilverSurferRWB
    SilverSurferRWB Member
    Bay Area, CA
    :amen: I 3rd it as well. Any sudden change in speed caused by a ill timed shift in a turn is a recipe for disaster. Just imagine if there was some sand or oil in that corner that you didn't see... :eek: Set up your speed while entering and ease her through.. smooooooth! :smokin:
  9. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    ditto on what squirrelman said. Never downshift in a corner and blip the throttle to match engine and wheel speed to keep the ass end from stepping out on you.
  10. mello dude
    Romania
    Didnt catch the mid corner thing (duh on me) - good points all.
    MD
  11. Fizz
    Fizz New Member
    San Diego, CA
    As the others said, you shouldn't be doing any shifting or braking in a turn anyway.
    But as for the CAUSE, my guess would be that the pressure from engine braking on the rear wheel is causing a temporary skid (Or potentially that your swing arm has too much play).
    If I'm in a turn and I'm in too high a gear (lugging the motor), rather than shift I just work the friction zone with the clutch to manage my roll on. Gears 2-5 on my bike feel REALLY close. First feels really far from 2nd... If I downshift to first at about 20mph and abruptly let the clutch out, my rear tire will skid.
    When it hops are you downshifting into first by chance? Or what gear in particular (if one)?
  12. love4vfr
    love4vfr New Member
    dallas tx
    Well it doe's it at any gear i'm at and I see now I just need to downshift before turning point blank, I must have gotten myself in the habit for some odd reason , I have ridden bikes my whole life ,I had my first honda cr80 when I was nine but this is my first real street bike that I have ridden on a daily basis , but thanks guys for showing me the error of my ways
    happy riding
  13. Gatekeeper
    Gatekeeper New Member
    Even on the race track, we don't routinely down shift in the corner. It can be done but it isn't the fastest way around the corner, or the safest.
    But for all the other times when you are shifting. Try to do it so there is no lurch when you shift. If you have a passenger, you don't want them to even feel the shift. Practice SMOOTH!
  14. VT Viffer
    VT Viffer New Member
    South Carolina
    My brother's '05 GSX-R 750 is notorious for skidding the rear end around when downshifting to 2nd or 1st... Even when straight up and before the turn. Even when matched perfectly, if you're not gentle with the clutch lever, the rear end will chatter. As a matter of fact, I think his '00 Monster 750 did the same thing!
    It's just one of the downsides of a 12.5:1 compression ratio... Lots of engine braking. The VFR (4G) is 11:1, so same deal.
  15. masonv45
    masonv45 New Member
    Many racetrack classes practice the mantra, "Be smooth, then speed will come automatically"
